- Year
- 1987
- Vehicle Model
- 4Runner
- Location
- United States
- Mileage
- 378500
- Color
- Red
1987 Toyota 4runner
JT4RN62S4H0100320
22re rebuilt motor less than 1000 miles
Manual - new clutch less than 1000 miles
No Rust! California Vehicle
Currently I am the 4th owner
I am in California for work and have been since March. My original plan was to fix the vehicle and drive back to MD. I was fixing whatever needed to be addressed so I would be able to reliably drive back across the country. Unfortunately I will need to sell out here. I travel up to SF and Monterey quite often on the weekends so I am flexible to show the vehicle.
378k On Truck
Rebuilt Front End <500 miles
-Inner and Outer Axles
-New upper and lower ball Joints
-Idle Arm
New OME Suspension (cruiser outfitters kit) - completed about 10,000 miles ago
- Ultimate Light Kit (Includes EVERYTHING) Part# OME4R1ULM
-Toytec 1.5" ball spacer
New AC compressor - converted to new refrigerant (also have spare)
New alternator less than 1000 miles
New heavy duty clutch from 22re performance less than 1000 miles ago
Rebuilt motor less than 1000 miles with new head.
Timing Set
Piston & Ring Set
Rod Bearing Set
Main Bearing Set
Pin Bushing Set
Oil Pump
Full Gasket Set
New Cylinder Head
Valves
Valve Springs
Valve Locks
Camshaft
Killer Top Toys configured with 2 windows on each side and stock rear glass
BIG O AT with ~25% wear
Bluetooth head unit with upgraded speakers
Hard Top included, new paint. (missing headliner)
New window and door gaskets
drive.google.com
$11,000
Damage to passenger side vehicle.
Cracked Dash, currently has cover
Windows go up an down
Door locks work some of the time
Rear window goes up and down from switch but only up with key
JT4RN62S4H0100320
378k On Truck
-Idle Arm
Timing Set
Piston & Ring Set
Rod Bearing Set
Main Bearing Set
Pin Bushing Set
Oil Pump
Full Gasket Set
New Cylinder Head
Valves
Valve Springs
Valve Locks
Camshaft
1987 Toyota 4runner - Google Drive
$11,000
