This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
and noisy too. So do I tighten the big nut in the centre??? Seems to me there are two threaded holes with no bolts in them...(?)
'82 FJ 60 D.D. Stock as the day she was born.(minus 36ft of vacuum hose and some other crap)
Their there for removal purposes
If its sloppy you'd better pull off the harmonic balancer to make certain the shaft isn't damaged. If that bad boy comes off while you're running down the road you'll be in a world of hurt.
1986 V8J60
There's a feeling I get, when I look to the West...
The pulley closest to the timimg cover is solid... no wobble... it's the double pulley thats attatched to that which is loose. I just can't see in there
rock scientist..
Staff member
s-Moderator
Moderator
interesting, I think that pullet is rivited on to the harmonic balancer..
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
ok I Think I can feal the rivets. The pulley wobbles but the rivets don't move
I've had one come apart at the rivets. Either replace the whole thing or maybe add some bolts to it before it separates.
rock scientist..
Staff member
s-Moderator
Moderator
I would get a new one.
they are not hard to replace..
Although it might do just as well to take it to a machine shop to true it up and then weld it.
So then to get it off do I just back off the 43mm nut in the middle???
That easy???
rock scientist..
Staff member
s-Moderator
Moderator
And then use a puller with those holes that seem to be missing bolts..
Isn't there some sort of sheetmetal locking washer too? The kind with tabs that fold over the nut edges - it's been years...
1986 V8J60
That easy???
If you've got a stout 43mm wrench - Yea, that easy. Lots of people have had trouble getting the nut loose and retightenined when finished. A common trick is to prop the wrench against the frame and ten bump the startere to knock it loose. Use extreme caution if you go that route.
rock scientist..
Staff member
s-Moderator
Moderator
If you get the nut off you have already taken care of the washer. It retains the nut
Will try to get to it this weekend. It'll be going to the machine shop too... almost $500 from the dealer for a new one.
Thanks for the help.
rock scientist..
Staff member
s-Moderator
Moderator
Betcha can pick up a used one for $30
rock scientist..
Staff member
s-Moderator
Moderator
Teh for sale and wanted section on mud would be a good place to start
