Does anyone know what the compressed and extended lenght is for front and rear shocks on the fj.
Do you have stock rims or after market ? If there after market what size and offset are are they, and did you have to trim the body mount ? Also do you have a photo that you can post ? Sorry for all the questions but i want 33's and figured i needed a lift in order to get them to fit. Thanks Todd![]()
Thanks Dawg, I hope you did'nt hurt yourself in the process. I'm looking at the Donahoe rear springs and shocks, there 23.89 and 14.65 for the rear shocks and the spring is 2 inches longer. The springs are 15% stiffer than stock. I'm also wondering if i can get the Revtek front spacers only until i can afford coilovers. I do not think the daystar will handle the abuse for very long . I also want to keep the factory rake of the fj . There's alot to think about and i do not have the money to switch out parts if i don't like the set-up. Thanks again for the help .
I have stock aluminum rims, and no trimming of any kind. The tires measure a true 32.9" tall. There is ZERO rubbing. You don't need a lift to fit 33's if you keep the stock rim.Do you have stock rims or after market ? If there after market what size and offset are are they, and did you have to trim the body mount ? Also do you have a photo that you can post ? Sorry for all the questions but i want 33's and figured i needed a lift in order to get them to fit. Thanks Todd![]()
