- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,822
Did it have a four speed before? While the clearance from the tube is find I dropped the back of mine for clearance around the transmission cover towards the back. While you can remove the bolts between the transmission and transfer case then let the transfer case swing to give you plenty of clearance for the hand back. There is not enough room to slide either the transfer case off the transmission tailshaft or pull the transmission/transfer case out of the pressure plate. To change my clutch without pulling the motor/transmission/transfer case I have to remove the rear motor mounts off the bell housing and drop the back of the engine down to get clearance. If I have the tub off my 68 I would solve the problem before installing the tub. Might do a little search in the 40/55 section on these to see what people have done.
