Long travel rear for a 100 series
Thank you, @BurnsCrew, and all who contributed to this thread. It looks like I need to start collecting parts. I would like to do this with my existing Dobonsons IMS.
I already have a set of Timbren rear bump stops.
I've been running without swaybars for a couple of years.
I would like to keep running the DeltaVS PCK. To me, the PCK provides more benefit than sway bars.
I was getting this kind of rear lift with Dobinsons C59-171 – 1.5″ lift, linear rate, with 880LBS constant rear weight
The springs and suspension from this LX470 are moving to a much lighter 02 model LC100.
I agree rear flex is way more important than front -- especially in my environment.
That is a lot of rake, Im thinking of running C59-223V, although I do want some good rear flex and clearance without it being raked too much.
My buddy did the cutting and welding of the shock mount relocation on mine (no photos) and these are the photos of his truck. He did his first, and I liked the idea so we also did it on mine with the longer shocks.
And here are some close ups. I believe he ran a sway bar for awhile afterwards. He is running the tough dog suspension. Without changing shocks and just doing the chop and relocate and bump stop drop, he gained a lot of down travel. He has a 1998 model, and did not need longer lines but spaced up his brake line.
I'm following your idea, and shortening the lower shock mount.
Knocking this out today.
Have you had any issues with the the butt welds?
I've completed one side just a few moments ago.
But thinking that I'd add in a few fish plates to reinforce the mount welds.
Doesn't take long at all. No more than a couple hours per side.
Took longer to get the welder sorted after someone else in the shop used it.
**EDIT: Ended up adding in some plates to reinforce the welded shock mount.
Might be a bit overkill, but cheap insurance.
Yea, the way Alex cut them. One slid into the other about 1/2-1”. So they overlapped and then it was welded.
How is this chop working out for you guys? I have longer setup but my extended swaybar links are suffering. Not sure if this is because I had bent my swaybar on a rock or if the extra flex was messing with it. This is close to my max but it will go a little further to where the top of the wheel is the same as the slider. Anyone have full flex pics? I know it's also based on shock length but just wondering overall with longer shocks.
I don't run any sway bars at all, so I have zero binding.
I did the cut while retaining full AHC.
The AHC does a marvelous job at keep the chassis balanced without the sway bars, especially when in sport.
Thinking about adding in an 'anti rock' rear bar set-up.
Don't have any pics yet.
Working on getting a 37" fitted this weekend and testing.
Very nice. I'm worried about the no sway bar no AHC. Antirock would be a cool setup.
