CharlieS
GOLD Star
Hi all,
Could I get some advice about your experience with loctite 518 and or FIPG cure time in cooler temperatures?
Alternatively, could I get someone smarter than me to translate what the MSDS sheet means? http://www.dekkervacuum.com/pdfs/uploads/Loctite518ProductDataSheet_6_27_2007_10_02_34_AM.pdf
Does anyone have similar info for FIPG?
I live in the Northeast and need to do an install that requires loctite 518 sealant (or FIPG). It is below freezing, and I have a heated garage (overhead 75K btu heater), but it is uninsulated so I can heat it up to say 50degrees, but keeping it there is very difficult to do. It is plenty warm enough to spend timein doing an install, but I am fairly certain that I can't easily keep it up to temperature for a full day.
For the loctite, the MSDS mentions Activator 7471™ and 7649™. Have you used these? What was the result? Would this help accelerate cure time in cooler temps?
The install isn't something I need immediately, so if I should put it off because of curing problems, until it warms up I can live with it. I'd rather have a good install than a quick install.
Thanks,
Charlie
Thanks,
Charlie
