My door locks start acting up in warm weather. Is there a current source for the lock motors that I'm not finding.
I think you need a Mabuchi FC-280PT-22125 with short shaft and brass collar. You may want to dismantle you actuator to be sure. You can ride around with the door panel off while your parts come in, I've done it before. I haven't used any one the ones from Jon, I swapped one from an actuator that had a broken cable when I had the one failure.
Will this same part # work on the back hatchback panel as well?
Did anyone try this on the back hatch? Did it work?
