Locating onboard air in a Single Cab Tacoma
Atlanta GA
Hey folks,
Already thinking about my next project, which will likely be onboard air. I was wondering if others with single cab 1st Generation Tacomas like mine have installed on board air on their trucks, and where they decided to install? I thought about doing an "under hood" installation but then figured it was awkward to use for tire fill ups. I've considered putting it behind the passenger seat but wonder if there's adequate room. I suppose those are the only two reasonable options. What have others done, and do you have pics of your installation? I'm thinking about going with an ARB system also, unless someone has any other strong opinions.
Thanks in advance,
S
Really? Does this mean no one has done this install, or no one has any ideas?
S
Cool - will do thanks
I would think that under the hood or in a box in the bed would be your two best options. Either way, you can/should plumb it in such a way that you have a female coupling at 1 or 2 spots outside the rig.
