Hello Guys,
My Front Blower motor crapped out last Weekend.
I pulled a motor/fan assembly off of a 1988 4 runner truck. They are the same part no and plugs.
While i was at the pick and pull, the 4 runner came with a rear heater as well. I took that out as well.
Although the part numbers are different, the assembly barely fits inside the center console.
I have looked at the wiring and am missing the relay (90987-02004) above the circular relay.
there is continuity between this relay socket and the 4-wire plug in the picture below.
I have a few questions,
1. How do i route the coolant hoses, Is there an existing hole in the Bed that i can use, or i would have to drill and knock a boss out of the floor?
2. What kind of T fittings should i use with the 5/8" heater hoses. Can the plastic poly fittings do the job, or just go with Brass fittings.
Any Tips are welcome.
Thank you All,
Ali C.
Thank you All,
Ali C.
