New battery.
But its dead if I let the cruiser sit for more than a couple days. I put a volt meter between the battery negative terminal and the frame. It looks like there is a draw of about 3.5A. That is quite a bit. I pulled every single one of the fuses (in the fuse box next to the driver's foot). Power drain didn't change. Maybe I should go through the fuses again. Are there other fuses aside from those?
I don't know if it's related, but regardless of weather I've got the key in the ignition, when the driver's door is open there is a dinging bell alarm sound. It like as if I left the key in the ignition in most other cars. Is this normal?
Looks like the drain is coming from the white wire. Any idea what that one does?
