Doc said:Ok, Cahil- I remembered I have the FSM downloaded... I'll look through that and see if I can find those relay's!
How do I test the 'circuits' you had broken down in post #12 when I find the relays?
Basically, after switching the relays and testing the lights and switching the headlights and testing the lights ... you have done a "shade-tree mechanic" test of those 4 circuits.
The next step would be to double check the FSM electrical diag to see if we have missed anything switching in the curcuit like an additional relay, something not solid wire. Most probably not but worth a peek.
If you have gotten this far it's either the headlight column switch(my choice) or something *really* weird.
But at this point if nothing has changed, the factory wires are intact & not hacked, I would take a hard look at dropping $75 clams @ Cruiser Parts for a colum head light switch.
Or ...
Break out an ohm meter and test the headlight column switch for a bad ground. Not simple but do-able.
After that if the headlight switch passes ... it gets interesting.
Need to break the circuit down component by component wire by wire and ohm test and trace each individual wire of the circuit. Again not simple but doable.
Whew ...
Cahil
