Light Question...
Can't figure out how to replace the bulb inside the passenger side marker on a 99 tacoma...any help is appreciated....
Henry
anybody????? I know you have to remove the light housing...just can't figure out how to get to it from inside the engine bay...
Does it not have any screws on the outside?
if I'm remembering correctly.....open hood. There should be a screw on top of where the light housing sits.......unscrew it. The housing should pull out (read forward). Turn the light/wiring harness to unlock it, and pull the housing away from the light. Change the light. Reinstall.
If you can't figure it out....pick up a chilton's or hayne's manual.....pretty straightforward.
Good luck.
