Light Mounts on front
Switzerland
I want to mount 2 lights on the front of my TLC without chaning the entire bumper. any suggestions on baja-style bars? thanks in advance
Do the LED bar that I did. I highly recommend it.
if you search the forum you will find many examples and links. I looked into QPAX a while ago.. http://www.qpax.nl/qpax/ but you can also fabricate a mount through the grill to have have two 7" lights. I will post a pic of that example later.
checked-out Qpax; not allowed to add any type of bar to the front of the vehicle. so far jc's light bar seems the only option, however i like the idea of mounting 2 lights "in" the grill.
Personally I love the integration of a LED bar done by jcmiro. But his neat solution requires shedding $$$$ for a reliable LED bar :( . Anyhow a friend of mine fabricated 2 mounts to hold his 100W Halogens 7". They hold good and look nice too. In few weeks ill probably do a similar work and will post more pics if interested.
that's brilliant, thanks! :cheers:
I'm looking to mount 2 x PIAA 4" HID's
I always spend a few more to get that OEM look/quality, but thats just me. Below is a Jaos product which is a front skid bar with mounting brackets/light setup.
Nice but you dont want nice lights as a bumper guard.
the lights have a protective casing :D besides LCKID got a SC cruiser so I doubt he has plans to take it offroading..but yeah dont expect to do pit maneuvers and not have the lights damaged :)
LED all the way. Check out Rigid Industries if you want the best quality as LED's are not all the same. I'm getting the E-series 20". You can switch it to spot or flood on the fly as well.
Yup, but you cannot switch from spot to flood on the fly. Takes about 1 hr of labor last time I switched the reflectors out. (its not the lenses, but the actual housing that needs to be changed)
You can also go with Baja Designs or VisionX all three all good and reliable. I personally would choose the newer bars with the CREE 10 watts LEDS. Those are the new generation bulbs that emit way more light.
Yep, my mistake. I was thinking of the Hybrid they offer which has both Spot and flood combo which is a great option for most conditions. I will look into CREE 10 watt LEDs. Rigid industries is pretty incredible stuff and made in the the USA so I'll find if they will be offering these bulbs and will look into the other light companies you mentioned.
Baja designs is the same as far as I know. Bulletproof design, usa made and assembled hardware (Fyi all LEDs and component boards are made in China afaik) just like rigid.
Side note. Cree the makers of all good LEDs are made in China. I just ordered a ton of eBay light Bars for my wife's truck. I'll compare quality when I install. I eat and feed my family by selling Chinese products so I'm pretty confident about their quality.
LMAO!:grinpimp:
