Lifting / Leveling
@JDWCruiserMS 200 has different suspension than 100 series. Coil set up in the front. Call 49 Tire in Richland MS. @wct49 will treat you right.
I would lift it personally. 3” is about right. Lol
No torsion bars. Springs and shocks on all four corners. Front are coil over.
If you do a search
(upper right hand corner)
or even better a site filtered search using Google,
you can find all kinds of options from OME Nitrocharger to Kings and everything in between (Bilstein, IronMan, Dobinsons, Tough Dog, OME BP51, Icons).
Each one has it's fans and critics. A lot depends upon what you want to use the vehicle for.
You don't want it level, by the way, you want some rake, rear higher than the front.
Good luck!
