Liftgate Help - beeping; not working...... (1 Viewer)
John Denver Land
Hello...
I lurk here a bit while building up my 2018 LC. Anyways, having a problem with the power liftgate; push the interior button or the fob and it will not work. beeps twice and will not open. i can manually open it but same thing happens when I press the close button on gate itself; beeps twice and nothing.
Any insight would be appreciated - I have searched here and the web and don't get any results. I HAVE tried holding the buttons, both on the lower dash and the gate, for several seconds trying to get it to reset, but that did nothing.
thanks
B
May need to reset your ECU. (Unplug the negative terminal for a few minutes). Keep in mind the ECU will take a few minutes to initialize, so you may have the same behavior if you try right away. I noticed this when I changed my battery last weekend. While initializing the lift-gate will not open until complete.
LX has a button to turn off the power liftgate. If it's off, it will do exactly as you're describing. Check and see if you accidentally pressed the this button...
  • Like
Reactions: cnd
Odd. This exact same issue started for me about 3 weeks ago or so out of nowhere on my 2020 LC. The power liftgate doesn't work in either direction with the fob or interior button. Same 2 beeps you described in OP. The soft close on the lower tailgate still does it's thing, however.
I assumed I inadvertently changed a setting in the lock/unlock menu or something like that.
Installing switch pros and compressor this weekend, so battery will get disconnected; I'll try that and see.
and the button to turn liftgate "off" (or is it on?) is not switched.
Pushed in = no power door. If you can see the red trim around the button, you have power.
you hurt its feelings.......... could have sworn i pushed that button and tested it... works again. silly button
THANKS!
I am having the same exact issue. Online searching shows a switch in the glovebox for Highlanders but my 18 Land Cruiser does not have such a switch.
Where is the switch you are talking about located?
On 2015 LX, it is to the right of the steering wheel.
Feel like there should be a liftgate sticky. This comes up at least once a month.
