Ok, so the BDS install is finally done, and I picked up four new 33x9.5 tires, as the 30x9.5 tires were way too small. Overall, I'm pretty pleased. The truck sits a bit higher than I envisioned, and the initial ride seems a little stiff. I suspect however, that the springs will settle a little, providing for a smoother ride and a slightly lower stance. The other thing I thought interesting is that the back end seems to sit higher than the front. I suspect this will settle down and will help compensate for any load. Anyone recommend taking a leaf out to soften the back end??
As far as the tire size is concerned, I did notice a difference in relation to when I would shift and the behavior on hills. Not bad, just different. No vibrations to speak of at this point. It looks pretty cool, I guess I'm just used to the sagging back end and not used to it being so high up. I'm going to post a pic today sometime.
