For sure, im being really careful to keep the throttle body with position sensor intact. Thanks so much for the help guys. Im having a tough time getting the large throttle plate off. The screw heads stripped easily so I had to drill them out. They were rivet on one side and screw head on the other. As you can see the drill holes are quite big and i expected the plate to come off but its stuck. The plate looks sandwiched between 2 halves of the axle. How is this supposed to come apart? The smaller plate came off easily as the axle was screwed to the plate on one side but the big one is a PIta. This is a picture of one side.
This is the other side. See how the plate is sandwiched?
Open the throttle so the plate is vertical, and gently tap it out? It's been so long I forget what I did, but I remember fighting with it too. It might only go one way. Spray some carb or brake cleaner in there so you can see what you are doing better?
