LED Tail Lamps For FJ100
If you're worried about having them say "SAE" or "DOT" on them, then I would not get them. ;) I've looked at the LED rears for the 80 and it does not say either one of those on them anywhere.
But I know that at least the ones for the 80 are roadworthy (will pass inspection legally) w/o any issues. That is not to say that you would not be ticketed in your neck of the woods, especially in Canada. ;p
I also noticed on that link it says, in fine print, Disclaimers: For off-road or show purpose only.
A lot of the aftermarket lights/lenses are manufactured in Taiwan, but the seller of these lenses is located in Hong Kong.
HTH's!
Mot ;)
Why does it say for 2001 and on why not 98 and on? I want'em!!! :cool:
The ones I've seen here which I would not be surprised if they were the same things are for the early ('98-'00-ish?) 100. You "should" be able to put them on no problem w/o any modifications.
The mid 100 (the current model is the "late" model) will require the back-up light housing part to be ground slightly for the socket to get in (All of these info. are according to one of the sellers, and/so I don't have any first-hand knowledge).
HTH's
Yeah, I see it's not DOT and SAE approved. It did say E-marked stamped. Is this the european standard to DOT and SAE as i recalled?
Has anyone tried these yet?
What's an FJ100? :flipoff2:
ha
OK so has anyone got these? Will they make the light failure light come on? At this price they should work perfect.
