A while back, probably a year or two, I had my windshield replaced. 1993 FJZ80. It has leaked a bit since, and now appears to be leaking worse. Even worse, my key light is now staying on. That means a room lamp control relay under the passenger side kick panel is going bad.
https://forum.ih8mud.com/80-series-tech/93395-ignition-switch-light-ring-does-not-go-off.html
I think these things are related-- I should have fixed this earlier.
Anyway, when the windshield was replaced, the gasket was replaced with it. I watched the guy replace the windshield, and he pretty much followed the FSM procedure. But now after looking at it again, I don't think he installed the sealant everywhere he was supposed to.
Specifically, he put sealant between the glass and the gasket, but I don't think he put sealant between the gasket and the body. It looks to me like the picture for step 5(b) on page BO-47 of the FSM (1994 version) shows sealant going on both sides of the gasket. I am about 95 percent sure he didn't do this.
I am thinking that is why it leaks. Sound likely?
So my question-- can I either go buy some sealant put it around the outside myself, or call the guy and have him do it now? Or does the windshield need to be removed and the whole install redone?
My guess is to try and put some sealant there. It is the last step of the install, so maybe I can just do it now. Even if it has been two years since the windshield was installed.
If you think this will work I will probably just try and do it myself. Any hints? Does the sealant need to go around the entire gasket/body area, or just at the top? And where should I get the sealant?
Jared
Jared
