Leaking sensor any idea ?
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
Reinstalling high pinion and noticed this little fella leaking away. Any idea what it is and is it an outing issue?
Hard to tell without a little more reference but I'd guess oil level sensor. Mine leaks a little.
drivers side, bottom rear of block directly over pan, leaking away. And I hate leaks.
Really easy to replace the o ring. No need to drain the oil.
Be prepared for the connector to break when you disconnect it. It's easy to replace. The o ring is flat and not a normal o ring. It's probably a hard and crusted on to the sensor. I had to use a pic to remove the old one. I'm pretty positive the sensor is held in place with 4 8mm bolts. They take very little torque.
