leaking rear diff
peoria, az
after a rough couple of outings my 60 has developed a leak at the front of the rear dif, on the backside of the u-joint. question #1-what is the seal called? question #2-how many bananas? any help from you gurus would be greatly appreciated.
It is called a Pinion seal.I changed about 6or 7 in the last 15yrs on my cruiser. there cheep and easy to replace.Do the front at the same time then yoy have a spare
just got my seal from c-dan with the ih8mud dicount :) its going in wednesday
Ditto that ...
And readup on how to set the preload on the pinion nut. You 'll need that for re-assembly. Beginners use a torque wrench, pro's do it by feel.
Cahil
I don't have the FSM's in front of me, but my (o)pinion is 75w-90 for front and heavier for rear. 80w-90 ?
Cheers,
Cahil
P.S. Sorry I know hat was bad.
:D
you can use 80w90 on both. same goes for the tranny and transfer case.
Yup, and if you go with the same fluid ...
Get yourself a 5 gallon bucket of it and a small hand pump. Heck of a lot cheaper too.
Cheers,
Cahil
Don't forget to stake the pinion nut.
Cheers,
Cahil
if you don't get a hand pump, then it will take longer and be very messy. i tried it w/o a pump and it sucked.
Cheers,
Cahil
nothing like the smell of gear oil and hawiian pizza. huh Cahil? :D :beer:
jhstatts said:
I hate the smell of gear oil in the morning.
i fillled my tranny w/o a pump and i got covered in the stuff. it took me 2 showers to get the stench off me.
HA !!!
That's the perfect comination, gear oil and Hawiian pizza !!! Let the good times roll.
I dug up this old metal siphon pump I had and now it travels with my Cruiser !!!
Cahil
P.S. Doing my front axle(knuckles & lockers) on Tuesday next week. Let ya' know.
lowtideride said:
sweeet... you at silver spring or daytona?
Silver Spring.
Mom's had enough with being run over with hurricanes for this season. Not only did the eye of Charlie go right over us ... Francis decided to hang out in town for a while.
Francis stripped the stop lights off the overhanging wires @ intersections. This is now my definition for a *bad* storm.
Cheers,
Cahil
haha, well good luck..when you coming down south agian?
If I can get her mental health straightened out ... toward the end of hurricane season. Other than that ... dunno.
Cheers,
Cahil
