I have a 1983 FJ60 with a PCV valve that's throwin out oil, coating the air filter and cover. I replaced the valve and the oil level is normal.
Any ideas?
thnaks
Any ideas?
thnaks
BTDT (Been There Done That)
look at my thread https://forum.ih8mud.com/showpost.php?p=8127483&postcount=59
to see my blowby, which was preceded in death by huge amounts of gunk in the air cleaner and fouled air filters.
This is ring blowby, as the head was rebuilt and is good
No pic of the air cleaner/filter, but that is a positive air flow, when it SHOULD be a negative pressure - air
draw from inside the air filter and drawn into the PCV valve. In this case, it is blowing out the intake port.
Not good - also, lost of power and gas mileage was getting bad
Since I am switching to SBC, that was end of that 2F
dougbert
Looked at your blowby pics. BUT:
-Where is the PCV? Can't see it.
-If installed, is it installed vertically?
-What are the other hoses and T?
-Is the blowby @ idle or brief accel.?
-Are the vac lines to the PCV installed correctly?
