LC200 fuse box (1 Viewer)
Dallas
how difficult is it to remove the under hood fuse box? I dropped something in one of the empty holes and it fell to bottom of box out of sight and reach. I've tried a shop vac and magnet...the only way it's coming out is to get inside the box. Do I need to remove all four bolts or just the clips?
thanks in advance for the help...
The box has a lid, a base, and then all those fuse holders are separate components. With the cover off, i'm sure you saw the plastic clips on the side of the box for the fuse holders, with a flat head the whole inside that all the fuse blocks are attached to can be lifted up enough to get a hand in there, there will still be wiring attached so completely removing takes more time by needed to unplug individual fuse blocks.
