While I was replacing my Center Diff Actuator, I noticed a lot of play in the front drive train. Here was my approach to measuring it. Maybe someone can challenge my observations and deductions.
I rotated the DS wheel (jacked up off the ground) and watched the CV assembly and the front driveshaft spin.
I measured 4 distances:
Measurements (tread inches / converted to degrees for 295/75 R16 circumference of 105”)
I think this is enough to say I need new hub flanges and I should replace the CV axles. Anything else I should do while I am in there? I assume wheel bearings, at least, and the seals between the diff and CVs.
But what do the measurements say about the health of the front differential? Or about the health of the Transfer case?
I did a visual check of the movement of the front driveshaft at the output from the Transfer case, and it appeared to have 30 degrees of free rotation.
I don’t really want to start replacing transfer cases and front differentials, but I will do it if its needed. I just want to know if any of this information indicates anything likely to fail.
My rig is a 2001 LC100 with 227k miles.
Records of previous owner front end work:
124k: CV axles rebuilt
192k: New outer tie rods, new inner tie rods, new SPC upper control arms, replaced wheel bearings, new aftermarket Left CV Axle assembly (guessing from $150 parts price)
- Tire rotation until Outer CV Axle began to rotate (play at the hub flange and outer CV spline)
- Tire rotation until Inner CV Axle began to rotate. (play inside the CV assembly)
- Tire rotation until driveshaft began to rotate. (play in inner CV spline and inside front differential)
- Tire rotation until driveshaft stopped (play in the transfer case)
- 1.25” / 4.32 degrees
- negligible / N/A
- 2” / 6.84 degrees
- 2” / 6.84 degrees
