Hi,
Planning to take my 2004 LC100 4.7 v8 (UZJ100W, JDM spec) for a service tomorrow.
History: First owner had car serviced at main dealers in Japan from new until 91,000km. Looks like they followed correct servicing schedules but I can't read the details. Second owner imported the car to Kenya at 98,000km and I don't have record of what kind of servicing he did. I bought it at 114,000km. Since then it's been mostly fine, at 116,000km I replaced the fuel and air filters. It's now at 121,000km.
I am planning to have my independent mechanic do the following:
1. Clean throttle body (this was noted during a Toyota main dealer inspection/diagnostic)
2. Clean MAF sensor (as above)
3. Check brakes.
4. Check suspension.
5. Check air filter.
6. Drain & change engine oil, oil filter.
7. Check spark plugs and maybe/probably change.
I know the timing belt is overdue at 100,000km and that is on my to-do list but not at this service right now due to difficulty finding the kit.
I considered changing the ATF fluid (A750F transmission, ATF-WS fluid I believe) but not convinced I really need to at this mileage, added to that I am not confident anyone here except main dealer (who charges $$$$ for anything) would do it right and I fear introducing problems. It's possible it got done in Japan at the advised 80,000km, but can't be sure. Similar story with changing LSD oil. Thoughts?
Regarding engine oil, my choices here are limited and were between Shell Ultra fully-synthetic 5W40, Shell HX5 regular 15W40, Shell "Super" regular. I got a comparatively good deal on the Shell Ultra 5W-40 so was planning to use that. Any reason why that would be a bad choice?
Does this all sound reasonable? Anything else I should do? Am I missing something important? I want to keep the car serviced well but have a limited budget.
Thanks in advance...
3. Check brakes.
