Well long story short, the LC started to pull to the left when i press the brakes, so i decided to upgrade the caliper with the 4runner 3rd gen. I got the all done, wet for a test drive and still pulling, so i check the rear and found out they weren't working the had no pressure, well i put new cylinder wheel and shoes
then i tried to bleed the system and no hydraulic fluid is coming out of the rear brakes.
After that i check the LSPV bleeder and is got pretty good pressure i also rose the lever all the way up, but still not work .
Any ideas what should i do next, or have you run into this issue, any advise will be appreciate
