Yeah I read on her to bypass that switch. Then it will just be on after the key is off for a certain time. Maybe I should try to hook it back up. the carb fan is workingYou nailed it, that’s the connector for the carb fan thermo sensor. The sensor is normally mounted under the intake on the firewall side of the engine. Sounds like you have that wire grounded instead of connected?
