Last Lexus Maint. recorded
Minnesota
Hello, looking to buy a LX570 and the maint records in general are great for this LX. But the last record is this... I have offered 26k for this 2013 LX570 that is extremely clean. Anyone have thoughts?
4/14/2023 (159289 miles)
REPAIR NUMBER: 4087658
REPORTED BY: Eskridge Lexus of Oklahoma City
SERVICE: 10,000 MILE SERVICE
DESCRIPTION: ~|~CHANGE OIL AND FILTER, REPLACE CABIN AIR FILTER, R OTATE TIRES, INSPECT BRAKE PADS, TIRES AND WIPER B LADES, CHECK AND ADJUST FLUID LEVELS, CHECK DRIVER S FLOOR MAT INSTALLATION OPCODE 00110F ~|~CUSTOMER REQUESTED 10K SERVICE ~|~PERFORMED 10K MILE SERVICE TECH660
SERVICE: CHASSIS ELECTRICAL
DESCRIPTION: ~|~C/S THERE IS SQUEAKING NOISE WHEN DRIVING AT ANY SPEEDS. GETS LOUDER WHEN ACCELERATING. BEEN DOING FOR A FEW MONTHS. THIS IS NOT ALL THE TIME ~|~DID NOT HEARD NOISE ON FIRST TRY. AVISED CUSTOMER TO REPLACE SEPENTINE BELT DUE TO AGE. HEARD NOISE ON SECOND ATEMPT AND DID CONFIRM NOISE COMING FROM DRIVE BELT. ~|~REPLACE DRIVE BELT FOUND BELT WORN AND DRY SEE DROVE BELT LINE
SERVICE: REPL SERP DRIVE BELT
DESCRIPTION: ~|~REPLACE SERPENTINE DRIVE BELT BELT: REPLACE DRIVE BELT ~|~FOUND DRIVE BELT WORN AND DRY ROTTING ~|~REPLACED DRIVE BELT TECH660 .50
SERVICE: SPARK PLUGS (8CYL): REPLACE SPARK PLUGS
DESCRIPTION: ~|~SPARK PLUGS (8CYL): REPLACE SPARK PLUGS ~|~FOUND VEHICLE OUT OF TIME AND MILEAGE FOR SEVICE RECCOMMENED SPARK PLUG REPLACEMENT ~|~REPLACE ALL SPARK PLUGS TECH660 2.5
SERVICE: TIMING COVER GASKET
DESCRIPTION: ~|~REPLACE TIMING COVER GASKET ENGINE TIMING COVER GASKET: RESEAL TIMING COVER AN D REPLACE CHAIN TENSIONERS ~|~FOUND SLIGHT SEEPAGE FROM TIMING COVER. INFORMED CUSTOMER, CUSTOMER WANTED A FURTHER DIAG ON SEEP. DROVE VEHICLE AND ALLOWED ENGINE TO CYCLE ALLOWED TO SIT OVER NIGHT AND FOUND OIL LEAKING DOWN FROM THE SAME AREA, INFORMED CUSTOMER AND ADVISOR OF OIL LEAK ~|~PERFORMED TIMING COVER RESEAL AND REPLACE TIMING CHAIN TENSIONERS TECH660 18.7
Are there any leaks? If not, I do not see any issue with the above. Good you have new chain tensioners.
Check the AC recirculation door is working as I see they replace the cabin air filter.
Do they offer it for 26k or is that what you offered them?
28,600 was the asking price I offered 26. Looks like it sold yesterday at asking price.
Noisy tensioners and timing cover leaks are a common nag on this motor. So finding one that already had the service would have been a boon.
Under 30k for a 13-15 model that obviously was pretty well maintained. Surprised someone sprung for all that front engine work and then sold it within a month or two. I know the prices on these are falling, but the asking price was probably a pretty good deal, unless there were rust issues or well over 150k miles.
That timing cover job was $$$. Would be great to pick up a rig that had that done already at a dealer.
