Land Cruiser - Fuel Issue? Something else?
I own a 2001 Land Cruiser. I hope this is the correct forum to place this. Anyway... it keeps having this issue where it starts, then won't start. When you turn the key you can't hear the fuel pump click, it's not getting fuel. My fiance replace the EFI Relay and the fuel pump, and the fuel pump control module ECM/ECU?
I have taken the truck to Toyota 4 times, they can't figure out what it is. We also replaced the battery.
I'm about ready to drive this car off a cliff... HELP! :)
You need to move this thread to the 100 series section. 100 series is 1998 to 2007, the 200 series is 2008+
Also, if the problem is with starting......why not check the starter???? What you described when your trying to start the engine is usually either the battery or the starter.
Thank you. I will move it now. I wasn't sure what series it is. It's not the starter. Toyota has already checked that. I just read my post though and had to edit, you can NOT hear the fuel pump engage when you try to start it. It turns over but is not getting fuel. :) I will move it now.
