Kzj78 transmission and axle fluid/oil
Singapore
I have a 1995 kzj78. Would like to know what fluids type is for my vehicle?
It has a 1kz engine with auto transmission.
Auto transmission fluid -?
Auto transfer case oil -?
Front axle oil -?
Rear axle oil -?
Hello,
From the FSM:
  1. Automatic transmission: ATF Dexron II. Capacity: 15.0 liters without oil cooler, 15.4 liters with oil cooler.
  2. Transfer: API GL-4 or GL-5. Viscosity: SAE 90. Capacity: 2.1 liters.
  3. Front/rear axle: hypoid gear oil, API GL-5. Viscosity: SAE90 (above -18 C/0 F) or SAE 80W/80W-90 (below -18 C/0 F.) Capacity: 1.9 liters.
Hope this helps.
Juan
Hello,
From the FSM:
Hope this helps.
Juan
Hi Juan, the volume stated are the actual volumes?
Are there only 1 transfer case? So just need 2.1L total?
1.9L are for both axles or 1.9L for each axles?
Hello,
Regarding your questions:
  1. The volumes are the actual ones.
  2. There is only one transfer case and yes, you just need 2.1 liters.
  3. It is 1.9 liters for each axle, which corresponds to 3.8 liters for both.
Juan
