Hello gang. 1995 kzj78 with the 1kzte. I am running 10psi on my gauge and I believe it's accurate. I've put it on the turbine side and the IM side and it's consistent. When I go WOT it stutters for the first four or five seconds then smooths out and builds boost. So I don't think it's fuel cut but it sure feels like it.
Things I have tried in no particular order: fuel filter, air filter, in tank filter, injectors rebuilt and pop tested all equal and nominal, I have some blow by but compression is within tolerance and spec, full size catch can, cleaned the map filter and hoses off manifold, new intake and throttle body seals, EGR deleted long ago and IM is clean and clear, valves are within spec, ecu is rebuilt, spill control valve is newish and adjusted to within spec, engine ecu temp sensor is new and I'm fairly certain that the other sensors are fine as the only code I sometimes get is a injection timing code but I rebuilt both of my resistors and they are tested within spec.
Do the map sensors fail regularly on these? Will be a couple hundred to get a new one to me if it's not the problem. Anyone else have this issue? I don't want to go above stock boost until I have an intercooler but I would like to be able to step on it and not go lug lug go.
I'm tempted to put a bleeder on the sensor side of the IM to see if that helps?
Thank you all in advance my wizards.
Lomo
Lomo
