KZJ70 1kz wont start (2 Viewers)
Angola
Hi, I'm from Angola and new here. After a lots of searching and reading i cant find a solution for my 1kz.
After a failing turbo at 400.000km i rebuild the engine, everything stock, then i send the injectors and fuel pump to a shop to clean. They said the fuel pump was bad and changed the housing for one that i believe by the numbers is from a 3L.
Now i cant start the engine unless use brake cleaner, it fires at first shot of brake cleaner and idles fines but if i turn it off it will need the brake cleaner again.
The engine is a 1kz-t with a full manual pump, the one that the acelerator cable connect directly on the pump.
Any help will be apreciated
Best Regards
You have a fuel delivery problem. It runs when you manually put fuel in (brake cleaner). Have you verified fuel at the injectors? IE: crack the nuts holding the injector lines to the injectors - to bleed the air from the system, but more importantly to make sure fuel is reaching that far? If no fuel, make sure fuel is reaching the pump and work back from there. Isolate the problem area first, then troubleshoot and mitigate. Best of luck! :cheers:
