1997 FZJ80. Here are the symptoms:
1) Pinging while cruising at highway RPMs in warmer weather.
2) Pinging stops when you let off the gas slightly or slightly give it some gas (both of which I believe are manually triggering timing adjustments).
3) No CEL
It's been doing this for a while. I'd like to know if anyone has experienced these symptoms and they turned-out to be caused by a malfunctioning knock sensor. If so, I'll go after the sensor(s), but every thread I've read regarding knock sensors involves CEL signals or broken wires, neither of which I have. My thoughts are that the ECU thinks the sensors are working fine but at least one is not sending any knock signal.
Carbon/EGR stuff has been cleaned out recently, so I don't think it's likely to be carbon pre-detonation.
Any ideas?
3) No CEL
Any ideas?
