- Thread starter
- #41
Got back at late this afternoon. Discovered the in-line fuse for the CB was blown (glass type). Replaced it and it still didn’t work. Can’t remember how it was wired up, but the previous owner had installed a 10 ga or so wire to the battery with an in-line fuse. Checked that fuse (15A) and it was also blown. Replaced it, and the CB had power!
Bad news is that the Kenwood unit is no longer working. First I cut the blue/white wire on the main harness going into the connector that mates with the Kenwood connector. I then cut the yellow wire on the other side of the Kenwood/Metra connector and ran a jumper wire between the two thinking that maybe there was an issue with the two connectors. No luck. I did this because I was measuring battery voltage on the blue/white main harness wire. It was around 11.8V which was essentially the same voltage on both my batteries when the engine wasn’t running (I hadn’t started it since J last worked on it). I figured the engine wouldn’t start, but it did, and with the engine running (idle), the voltage jumped to about 14V at both batteries and around 13.8V and the blue/white wire.
Thinking I should find another 12V source under the dash I cut a red wire where I had soldered it to another red wire hoping it was 12V, but it had no power. Then reinstalled the wire I had used previously from the battery directly to the yellow wire (12V batt power) I had cut going into the Kenwood unit. Still no luck, but with those two wires connected, I was getting the blinking security light. Tried resetting it by depressing it, but no luck. I reconnected the two red wires, and still nothing other than the flashing security light. Super frustrating. Maybe I did something when I was cleaning up the wires to amp. Can’t think of anything else. Started raining again, and was getting dark, so called it a night. Suggestions?
