Ok so I know there are other threads talking about the lean but nothing that helps me. I have a 2007 GX470 Sport w/KDSS. I had a shop install my Ironman 4x4 Foam Cell Pro kit Stage 2 w/UCAs and rear adjustable panhard bar. I had Ironman send the front coilovers prebuilt and the spring seat heights already set. I also had the Treat oaks full set of KDSS spacers put in. So normally these things lean down on the driver side but I have a big lean on the passenger side. Pretty sure the shop that installed my lift did not open the KDSS valves during install. I even tried my self on a lift but cannot get access to the 10mm hex bolts that are on top of the actuator. No room.
Distance from center wheel to fender:
RF - 21.25"
LF - 23.50"
RR - 22.75"
LR - 25.50"
I really need some help here. Is this a KDSS thing? Do I really need to equalize the pressure? Should I remove the KDSS spacers on driver side? I am so lost. Ironman 4x4 confirmed that driver side spring seat height is set higher to counteract the normal driver lean.
RF - 21.25"
LF - 23.50"
RR - 22.75"
LR - 25.50"
