KDSS front sway bar
Oregon
So a shop f'ed up the bolts that connect at the ends of the lower control arms and since they're connected to the lower control arms, fixing it is t the easiest thing. I need to have the bolts cut off the control arms and the the hole tapped for a larger bolt.
So, that being said, would it mess up the kdss system if I just removed the front sway bar and replaced it with the total chaos lower control arms? That's what I wanted to do in the first place but now I have a reason to.
TC lowers are not KDSS compatible.
yep
I just want to make sure I can remove the front sway bar without the kdss freaking out.
Once you replace the arms and "go big" the KDSS becomes irrelevant and a limiting factor. Call MetalTech and ask to Mark, he can give you his perspective.
You can also just drill out the holes on the brackets, and use a nut and bolt on the back side.
