KDSS Delete 2005 GX
Florida
Having an issue with the KDSS system and going to delete it and replace with aftermarket rear sway bar and oem front sway bar. My question is how do I get the KDSS light off after removing everything? I've searched and can't really find anything.
FYI unless you plan on welding in sway bar mounts, you can’t put an OEM non-kdss sway bar on a KDSS truck.
Will follow this closely. Was something I’d considered for my truck, but couldn’t find an example anywhere online.
Best of luck!
Disconnect the KDSS controller in the left rear quarter panel and it would not give any warning any more.
I assume I access this through the rear cargo area by removing the plastic panels? Do you know what the controller looks like? Don't want to unplug the wrong module ;)
UPDATE:
Found the controller. It's on the rear driver pillar about halfway up. Unplugged it and the light went out. Thanks for the help!
UPDATE:
Excellent info. I'll have to save this!!
