just got a canadian m101 from Clint, who delivered it with a new (to him) 80, found at exped.portal.
so, the good:
* 1992 m101, one of less than 2000 made. this was one of the ones that was brought down a few years ago, that IPOR got a bunch of.
* he did the fixing /welding of the tongue, replacing rusted C channel with 2x3 box.
* only 1 spot rusted through, on the DS wall, near the back, the floor of the bed is sound
* he put modern leaf springs and shocks, and augmented the hardware to fit..
* 35" mtz's, so my 37's should fit without too much trimming (my goal is to have same tire/size as the main rig)
* bolted yakima type basket, solid enough for the tent and other gear for non-camping trips
* he built a lid, that locks, and has decent seal
* nose box, the delta is better than nothing
* water box/bladder below the deck, not yet plumbed, but it's been mounted
* thule 'sink' attaches to rear panel
the not as good:
* the hubs are jeep 5 bolt pattern.
* no brakes
the plans:
1) make it use the same hubs so that i can share a spare. He didn't believe that the axle he used had a 6 bolt toyota hub offering, as the internals may be different, but i'll inquire and i will price just hubs from his source (northern tool) so that i can use the 3 spare tundra/sequoia rims I have, and some beat 37"'s that came with my truck.
2) if a new axle is needed, other than what he used, northern tool, any input on who i should check out? if i'm swapping the axle, i'd be interested in e-brakes - the less strain i put in the '80 the better i figure. anyone have an experience with an e-brake conversion?
3) it's white, not bad, but it has a few surface rust spots i'd like to por15 and paint over. It'd be nice to get it to blend a little better.. we'll see...
4) batteries: in the front box, to power stuff like fridge, ipad/walkie/etc charger(s), and maybe a 12v pump to make the water box actually squirt. need to figure my trickle charger, solar panels look useful, but not cheap (plus an charge controller)
i've been in the market, and looked at 7 brands of new ones, many without a US source. i wrote off the Kimberly Kamper (crazy expensive) but there's a damaged on on ExPortal for $5k ($34k list !!!) but the stuff it has (kitchen, heater, water, power) really can spoil you....
so for now, we chose a not-only-camper, rather a utility/sport/camping trailer, which happened to have an RTT.
the wife is not so sure... but we outvoted her!
so, the good:
the not as good:
* no brakes
the plans:
