Just FYI manual mistake,
Dixie co. Florida
Was looking at torque for the front drive-shaft bolts and noticed a discrepancy in the 96 LX FSM. In the components view for the differential it shows
74 Nm
20-LB'
Well 74 Nm is 54 LB'
It is shown correctly in the drive shaft components and in the torque specs for the drive shaft section (PROPELLER SHAFT)
Thanks Raven. Any more typos?
:D
-B-
Thanks Raven. Can you please review the 97 FSM and let me know if you see anything? :flipoff2: :D
Actually for the ds bolts, I just put them on by feel. Want them tight, but loose enough to get off on the trail just in case :D
at page EG201 of the 94 FSM the reference in item 3 to the "front No. 3" exhaust pipe should be to the "rear no. 3 exhaust pipe". Please make a note.
Do I win $5 ? :flipoff2:
OK I'll keep to myself then :flipoff2:
That is actually not a bad idea, they were a bear to remove, some I got of with an impact, the rest my tired impact could not remove, had to use double wrenches.
Just need to make sure they are tight enough, anti-seize would be good here.
