WOW, ok... Let me explain...
I did the ahc flush last year and followed LexusBen's guidelines: https://forum.ih8mud.com/100-series-cruisers/60619-changing-out-ahc-suspension-fluid.html - Thanks Ben, very handy instructions!
But the issue is that I only had 1 can and when I got to the final corner, I didn't have enough AHC fluid to finish the job, so I only was able to do the 3 sides. I also noticed the reservoir was a bit lower than I was comfortable with especially in high mode or while equalizing if I have a load in the truck as I tow now and again.
Anyway, this time, I did exactly the same procedure, except I started the vehicle in HIGH mode (as opposed to just normal mode) for each corner and draining all old fluid out from there for each corner. Then, for each corner when it was stabilizing, it would go back up to high mode, and I did this procedure on the remaining 3 corners (obviously making sure I had enough fluid in the reservoir the whole time.
I do feel a slightly smoother ride (over harsh road imperfections and such). Not only that, I filled a little extra fluid in the reservoir at the end to make sure there would always be enough under load (a little about the high mark.) Make sure you don't put too much in though because when lowering suspension, you will have fluid everwhere!
Anyway, just thought I'd post this and mention I used 1.5 cans in total and I think I got almost all of the old fluid out this time.
One thing I noticed is that the rear sides both take a lot more fluid than the front ones do. Interesting.
