Has anyone ever considered replacing their failed AHC accumulators with something similar to these units sold in McMaster?
Scroll to the bottom of the page in the link to reveal the Diaphragm-style accumulators. I'm not 100% sure of the size of our globes, but I assume they are about 1 quart. Buying a set of 4 + the charging and gauging assembly should allow you to recharge your globes after they depressurize, at a total cost of $1250. Cheaper than the B&B option, but untested at this point.
Note that there are a few variables to consider which I am not completely familiar with; The McMaster accumulators handle 3,000psi max and have an SAE-type fitting. There is also a flow-issue which means that the port size of the accumulator must be equal to or larger than that of the OEM one.
Has anyone given this some thought? I own an 05' LX whose globes WILL eventually fail. If something like this can help us refill them after a few years, even if you can only refill them twice (or 3x) before they fail, they are worth the investment. Afterwards you would only need to buy new accumulators (4 for $891), not the charging kit.
Any thoughts?
Any thoughts?
