Is WD-40 Specialist silicone lubricant safe to be used on suspension components?
I've had this noise that's hard to describe from likely the bouncy springs for a while now. I have Dobinson front shocks and OME coils in back. Also set of new bushings installed.
Noise can only be heard at low speeds in parking lots or residential streets, not loud enough to be recorded either.
I was wondering if the WD-40 Specialist silicon lubricant is safe to use and just blast all metal/bushing contact areas? It says it is safe on rubber and plastic so just in case there's overspray onto nearby rubber seals or gaskets so I don't degrade those.
