Is BG FRIGI-CLEAN KIT Available Anymore?
Anyone have any idea of the self-tapping brass fitting BG used to supply with this kit? Ordered a Frigi-Clean Kit from Amazon and now there is a wedge you use to shoot up the drain tube, since several idiots drilled too deep into the evaporator coil using the old method. I like the idea of foaming between the blower and coil and having a capped port for annual maintenance.
If I had to guess.. 1/8 NPT x 1/8 NPT Male. Buy it, and take it to your local hardware plumbing section and test fit to find the right part...
This has been my backup plan if I can’t find the original offering. Amazon should deliver the cleaning kit today. Once I know the OD of the rubber tube, I can find a coupler like one above and match it to the ID and then hopefully find a threaded cap to close it up afterwards.
