I need some help. I want to buy a winch, it seens to me M8000 is a little small but nice prices on the market; M12000 it sounds like the perfect one but expensive. So I am thinking to go with xd9000i. I go four wheeling maybe 4 times a year and I haven't had the necesity of one, but never look for something that I could use the winch.
what do you guys think???
thanks.
The difference between the M8000 and the XD9000i or XD9000 is a little wierd.
The M8000 uses a slightly more powerful motor and has slightly faster line speeds, while the XD9000i uses slightly less current for a given pulling power...based on the information on Warn's website.
It's not hugely likely that you'll stall a winch, but you end up stalling an 8000lb winch, you'd likely stall a 9000lb winch, because you're most likely be stalling pulling less weight than the rating, but because you have too many wounds on the turn and not enough leverage to reach maximum pulling power. The maximum rating is with the winch spooled almost all the way out.
In any case, you'll almost certainly need to double line it either way if you need anything more than a basic tug, and with either the 8000 or 9000 winch, you'll likely break whatever cable or rope you're using before you reach maximum capacity in a double line pull.
So I personally see no real advantage to a 9000lb Warn winch over an 8000lbs Warn winch, unless the two winches are nearly the same price...which they usually aren't. The M8000 is usually far cheaper.
Also, depending on what bumper, winch mount you have, the XD9000i, may not fit. The ARB bumpers mount the winches feet forward, which means you'll have to get an M8000 or an XD9000 or simliear design with the seperate solenoid pack.
That's my opinion...but I could be wrong. YMMV
