Hi all, I'm Dave from the Chattanooga TN area. After having our third kid, we knew it was time to get a bigger car. Somehow I locked in on the Cruiser as a fun/capable and somewhat unique car. I just bought a 2005 LX470 with 193k miles and am falling in love. A huge thanks as I've already received a bunch of help from folks on this forum
The good:
-New Radiator and hoses 5k miles ago
-TB, water pump, crank seal, drive belt, belt tensioner and rear brakes done 10k ago
-Rebooted CVs, new valve cover gaskets and tube seals, 20k ago
-Wheel bearings repacked 45k ago
-I replaced heater T's the day I bought this
Work that I know needs to be done (with time and budget allowing)
-Steering wheel noise that hopefully just needs some lithium grease between a few parts
-Speaker repair.
-Third brake light glue caulk (temporary fix for it being cracked and loose as OEM replacement is expensive)
-AHC flush and inspect/calibrate (it does go into all three positions)
-A little rust remediation underneath (pretty good shape though)
-Figure out some sort of bluetooth capability
-A spare key (only came with one but it is a master)
-Paint chips on hood and some oxidizing in those needs to be addressed
-Remove the wind/rain window guards (not urgent but I really don't like the look)
AND here is where I need my first bit of advice. The windshield seems to have been replaced, as I have read, this is rarely done appropriately. I don't THINK I have any leaks from it, but definitely more noise than I would expect and the trim pieces that run on the sides between the windshield and the frame are wavy/bumpby and very hard. Pictures are below of this issue, and I have others of where this trim meets the top if that's helpful. Is that something that I can replace myself? Should I if it doesn't seem to leak, as in what's the risk? I am just afraid of pulling that trim off and getting in way over my head very quickly. I've read some of the other posts on this, but feel a little unsure about what steps to take next. Also, I'm probably not in a place to drop 1500 bucks on redoing the whole windshield with OEM glass and everything. Thanks for the help in advance!
The good:
-Speaker repair.
