I've had the pleasure of knowing some of you like minded fools for a long time. Others, I met as recently as last night when I officially joined this motley crew. Thanks again for the warm welcome.
I always had a mild case of the bug (drove a 100 series for several years), but it recently escalated when I came across the 60.
I promised some of the guys last night some pictures in the daylight, so here's the situation:
Body (other then the front bumper) and suspension are stock. Body is in good shape: No rust, paint and clear coat still looking good. Got one little dent on the passenger side nose from the P/0.
Engine is the original 2F with the spider web of smog hoses:
On the bright side, engine only has 113K original miles (a mild case of the cold starts, but otherwise as good a runner as a 28 year-old 4 speed 6 cylinder can be).
Interior condition is pretty clean (has the common tear in the driver's side seat):
It's got a couple of minor heat cracks in the dash (I've got the aftermarket cover for it, but I'm not sure I will use it):
Here's the bench seat:
Still figuring out the plans. I have a couple of small projects that need attention and then a lift is in its near future. Bought some springs yesterday from our friend Rob - just need to piece together a few other parts. Look forward to spending more time on here (and out there), and I truly appreciate the help I have already received.
