Introduction: First time LC owner, '94 LC
Georgia
Hey folks, just wanted to pop in and introduce myself. Name is Ted and I live in Georgia, USA. I'm a first time LC owner. I have owned several project cars in my life but this will be my first LC. Also in my stable is an 2002 4Runner (N180). I purchased this one from a local for what I felt was a fair price considering its history and condition. It has a little body rot and non-structural under-body rust (primarily concentrated behind the rear bumper. The engine was rebuilt 20k miles ago by a shop in TN (paperwork was included). The one interesting bit about it, which I imagine is the primary reason I got it for such a deal, is that it has a rebuilt title. What is interesting about that is that the rebuild was in 1996, just two years in to the vehicles life. Despite this, it's been on the road as a daily driver / project car for the last 30 years. Assuming those first two years saw the average American annual mileage of 15k miles, that means it saw another 220k (~8k/year average) over the last three decades, putting my mind at ease about any issues lingering from the rebuild. Unfortunately, the details of the event that lead to the need for a rebuilt title on a 2 year old truck like this have been lost to time but I have to imagine it was fairly substantial for insurance to do such on a relatively expensive, new-ish vehicle.
The truck is not without its problems, obviously, but I felt that they were openly disclosed and the price reflected the condition fairly.
The Bad:
  • A/C non-functional (but no seized). Seller said they never tried to diagnose it and I have no reason to not believe them based on how transparent they were about everything.
  • Suspension completely clapped out. Mounts are still solid. Easy, if pricy fix. OME 2" kit ordered.
  • O2 sensor needs replacement
  • Oil level sensor is broken (dummy light always illuminated despite proper oil levels)
  • Rockers are rusted through in places. I'm planning to cut them out and replace them completely anyway
  • Rear end is very rotted out. The rear bumper cover is held on in places with zip ties due to factory mount points missing. Confirmed the best I could that the rot does not extend in to anything structural, though, and was reassured by a local fabricator that cutting out the rot and building a replacement bumper was feasible without much trouble.
  • Center brake light is out. (I've already diagnosed it as a break in the wiring at the hatch joint).
  • Radio is non-functional (don't care, I don't listen to music when I drive)
  • Drivers side window is off the track and fickle due to broken plastic guide
Now for the good:
  • Engine was pulled, stripped, machined and rebuilt 20k miles ago (paperwork included)
  • Transmission is smooth as silk
  • Interior is in what I would consider "Fair/Good" (minor tears in the upholstery, carpet is mint, door cards are in tact, dash is un-damaged, jump seats are included and working)
  • No fluids are leaking and all fluid levels are good and regularly and recently changed.
  • Knuckles were just rebuilt by the seller
  • Low range works without issue and smooth
  • Starts easy, no smoke, idles smooth
  • Several aftermarket accessories were included
    • Rhino rack
    • Brand new, unused 270 awning
    • Nearly new 35s mounted on OE wheels
    • Diff breathers (included but not installed)
    • Intake snorkle installed
    • Front brush guard installed with LED flood lights (mounted but not currently wired in)
Plans:
Been working on a prioritized plan to tackle the issues starting from those that are critical for safety or to pass the rebuild inspection get the GA tag. Here's what I've got so far:
  1. Fix suspension (OME 2" kit as mentioned before)
  2. Fix center brake light (repair wiring and rebuild OE light bar, known to be non-functional)
  3. Replace O2 sensor and make sure CEL clears (needed for inspection)
  4. Find a way to "make the oil level light go away". This is still TBD and I'm open to suggestions. The replacement sensors I've found online are $$$ and I'm knowledgeable with electrical circuit design so I'm thinking of reverse engineering the signal and "faking" the signal to turn off the light unless there's a simpler solution (I haven't thought much about this yet, I am probably over-complicating it).
  5. Repair/replace window guide
  6. Diagnose and fix A/C before it gets too hot this summer
Anyway! If you made it this far, thanks for reading. I've attached some pictures. Enjoy!
You have placed this in the wrong category. Should have listed it under "the bad". Brush guards are better known as damage multipliers. They foldup like a pretzel, can't protect anything because there is no strength in the material. With any type of contact most likely that will also damage the hood when without the grill guard there would be no damage. Get a real bull bar or aftermarket bumper.
Hey Phil, don't worry! The plan is to pull the front and rear bumpers and replace them completely as part of the build. I've not finalized the exterior upgrade BoM so far looks like:
  • ARB front bumper
  • Custom rear bumper
  • Sliders
  • 2" OME lift
I'm new to the off-roading world and the parts listed are functional replacements for parts that are falling off already. I'm sure I'll come up with more ways to keep money from burning a hole in my pocket.
You are gonna have some fun with that truck. Don't know if I've ever seen the gray leather seats in such good of shape. Nice find.
Looks and sounds like you got a good deal and good luck with the build in whatever direction you end up going.
Here is a non-mainstream suggestion: since it has rust in your rockers you could do like some of the Aussie (I'm sure others have done this as well) and cut out the lower rocker and install sliders in their place. All depends on the level of work you want and the use case for the truck. If not, cut out the rot and replace the rockers then do the sliders.
FYI, the rear bumper center section is actually structural to the frame but if rust is present could be repaired. There are some post of people cutting the stock crossmember out and replacing for a better departure angle. In addition, IIRC some of the aftermarket bumpers also have you cut it out.
As for the oil level sensor, it has been talked about many times for various reasons but if you put this, ih8mud 80 series oil level sensor, in the search engine of your choice you should get some links. The search function on the site is not that good.
Lastly, if you haven't ordered the suspension yet, I would recommend Dobinson over the OME.
Download your manuals for free here on the site, they will help diagnose and work on the 80. https://forum.ih8mud.com/resources/categories/80-series.20/
Our Extreme series rear requires you to cut out the rear crossmember and some of the frame rail. Our regular modular bumper requires just the crossmember to be removed. You replace it with stiffer brackets and hitch receiver.
The seats are in great shape. There is a small tear on the bottom inside edge and inside bolster of the driver's seat but otherwise they're in really good shape. The tears are very clean and could probably be patched/repaired without needing to replace the full panel.
What bumper is this? I am looking around at options currently and I really like the look of this one. It looks like it would replace most of what is rusted out on mine.
@Brindleboxer, I've attached one of the images that JWNissan shared that highlights where the rot is on mine, it's all under the bumper cover but the frame/bumper/crossmember are all in good shape, just surface rust/corrosion
Sorry mate. Forgot the link but also didn't want to push our product. Just wanted to illustrate how aftermarket bumpers could help.
All good, my friend! I have bookmarked the site. I really like your modular rear bumper design. Going on the list of options to consider. Cheers!
