GTSSportCoupe
2LTE abuser
Some of you may recall I did my head gasket this past summer. Had a small leak to a coolant passage from cylinder one that was causing me a bit of grief while towing. Head was in great shape with no cracks (magnefluxed). I had already ordered a brand new one, so thats what the engine has now.
Anyhow, while doing the job, I noticed the head was not the original and had already been replaced (in Japan). It had cleary been rushed, which is why the gasket had failed. The other thing I noticed, is the rear three cylinder bores were stained/pitted from when the first head must of let some coolant/water in. It was pretty dissapointing.
Since then I've been wanting to test compression to see if I should consider getting a core and doing a bottom end rebuild. Recently I borrowed a compression tester from Rob (Diesel cruiserman).
Today I finally had a chance to test. I got the engine up to operating temperature and did the test:
Dry and hot: #1 440psi #2 410psi #3 405psi #4 410psi
Did another test with a bit of oil to test the rings. This was about 1 hour later and the motor had cooled down a bit: #1 445psi #2 440psi #3 420psi #4 430psi
The factory spec is 441psi, 284psi minimum, difference of 71psi or less.
Anyhow, what do you guys think? Keep beating on it, or look for a used bottom end to rebuild and swap in at some point? The perfectionist in me wants to rebuild it and have things perfect. However the practical side of me says nothing has got worse about this motor since I've owned it, so why bother fixing something that aint broke.
