Did you maybe torque them with anti-seize? I believe the book torque is for dry.
Shows up after cold start until it warms up. Will shock/pulse the brake pedal harshly when depressed and the RPM's will thud/drop for a split second but nothing noticed while the truck is moving. Here's what I tried so far... but problem persists
problem still persists.........
? There also didn't seem to be any issues this morning during the 10 minute drive to work with the hammer down. We'll see how it goes after work.How difficult is it to replace the throttle position sensor?throttle position sensor on the side of the throttle body could be going. I am a master certfied toyota service consultant with Toyota for 15 years and the owner of a 2000 l/c with 205k on it. Be careful, some dealers will tell you to change the whole throttle body but the throttle position sensor is avaialble seperatly. I had one go out on mine but it failed more dramatically in that once it failed it stayed failed until I replaced it. Maybe this will help?
