Description
o Sometimes my brakes feel "slow." They won't "grab" and I can't lock up the tires. The pedal feels a bit hard when this happens, and I use more pedal force than normal.
o The problem most often occurs when I first start driving, but also occurs randomly when running warm.
o I never have a soft pedal.
o I pass the test where the pushed brake pedel sinks when you start your engine.
o It is not linked to heavy braking.
o Its most noticeable at slow speeds. It's that last litle "grab" that's missing when you want full braking.
o It's a 94 LC with 120K miles and 33" tires.
Guesses
o Contaminated brake pads? I did spray PB Blaster in the same general before my lift, but I was careful not to hit the brakes. This probably isn't it because the brakes are usually good. They'd always be bad if they were contaminated.
o Brake boost failure in progress? If this is the case, then why does my pedal sink when I turn on the engine after pressing the brake pedal?
o Vacuum leak? If it were a slow leak, I'd expect to never have the problem after freeway driving.
Any suggestions?
Guesses
Any suggestions?
